  • Hey everyone! Enter your ride HERE to be a part of this month's Ride of the Month Challenge!
1 - 4 of 4 Posts
How does one get the Utopia backrest out of the seat. I thought it just slid in and out of the slot like other backrests but I keep pulling and it won't budge.
I think ya gotta pull the seat and unbolt it from the bottom.
You do not need to remove the seat just to remove the backrest
If you have the "original" you must remove the pivot bolt at the base of the backrest that secures it to the permament bracket that is screwed to a mounting bracket from under the seat.
If you have the newer QUICK OUT option a sturdy jerk upward on the backrest will release it.
The back rest proper can be removed by un-screwing the hinge pin. (I replaced that with a square wire lock pin.) To remove the rest of the back rest, you have to take the seat off and un-bolt it from the bottom seat.
(Typing while "the dawg" was posting)
1 - 4 of 4 Posts
