1 - 3 of 3 Posts
FYI: I lost one a few years ago -- for whatever reason -- and now, have drilled a hole in them and loosely zip tie them to the crash bars.
Doing so might save you from losing one, if you use them or a similar product.
BTW, this product defintely helps keep the toes warmer in colder weather.
after lots of miles of use i lost one, contacted Tulsa and bought just one to replace it, that was expensive ! then i lost the other one !! bought a used set from a board member so now i have one spare hotfoot, i think what happened was after a lot of use the spring simply broke thats why they fell off, so i did like u drilled a hole installed a rubber grommet and zip tied them to the crashbars so they can't fall off if the spring breaks, Tulsa hotfoot works pretty good for keeping feet a little warmer in cold weather :thumbup:
http://www.allamericanprod.com/order.html
1 - 3 of 3 Posts
