Yep, I've used one of those to check for a mouse in the filter housing - all clear and saved a lot of work. A few dollar ebay purchase and it plugs into my phone, the cable is 4 meters long so it's very useful for other stuff too.Has anyone found a way to check the air filter condition without tearing into the air box? I thought I read something about using one of those remote camera to probe the air box.
Where do you enter the camera at to get into the airbox?Yep, I've used one of those to check for a mouse in the filter housing - all clear and saved a lot of work. A few dollar ebay purchase and it plugs into my phone, the cable is 4 meters long so it's very useful for other stuff too.
Through the intake duct in the fairing. However, if you have covered the snorkels with wire mesh (which you should do on the FIRST filter change), you won't be able to get past it with the camera. I'm considering investing in a camera to just leave inside the housing - the built-in LEDs should light it up plenty to see what is going on. Maybe lead the wire out to coil up under the left glove box.Where do you enter the camera at to get into the airbox?
What he said! :wink2:Through the intake duct in the fairing. However, if you have covered the snorkels with wire mesh (which you should do on the FIRST filter change), you won't be able to get past it with the camera. I'm considering investing in a camera to just leave inside the housing - the built-in LEDs should light it up plenty to see what is going on. Maybe lead the wire out to coil up under the left glove box.
I like that idea since cameras are so inexpensive now. My only concern would be dirt build up on the lens after a while.I'm considering investing in a camera to just leave inside the housing - the built-in LEDs should light it up plenty to see what is going on. Maybe lead the wire out to coil up under the left glove box.
And the mouse would eat it! >I like that idea since cameras are so inexpensive now. My only concern would be dirt build up on the lens after a while.
