Hi,
Bought the Honda OEM Fog lights, figured I would study the directions tonight and do the install in the morning. Everything seems easy enough. But you have to remove the left cowl trim molding to get to the screw to remove the panel the switch goes in.
How do you remove the trim molding? I'm don't want to pry it up and break it.
Thanks in advance,
Spike
fog
have a plastic nife? the moulding pops off easily. just dont scratch the paint
Put a finger on the bottom edge of the trim and gently work the trim out (pull the edge out with your finger tip). It will pop out and then just work your way up. The tabs are tougher than you think but still use caution, you really won't need much force.
Al
2008 airbag
Like alzipp said above, grab the bottom trim and squeeze & lift at the same time. Then just follow it up. I think there are about 8 or so tabs.By squeezing the trim you are less likely to break the tabs as they come out.
Foglights are in
Hi,
Thanks for the reply's on getting the cowl trim molding off. Came off easy enough. Got my lights installed. Not a bad job. The lights themselves were easy enough. Could have used a little more room behind the headlight adjustment panel. But I got my fat fingers in and all works fine
Thanks again for the help,
Spike
