1 - 2 of 2 Posts
I started trouble shooting and found a suspect rear seat heater switch. The resistance in the off position is spec'd at 2.9K ohms and my meter read 6.0K. As you progress toward the MAX sw. position the readings do begin to fall off but don't come back into spec until the MAX setting at .9K .
The problem is intermitent, always heating initally but sometimes shutting off after 20 mins. or so. Everything else re: the new Corbin seat meters to spec. I don't have a proven heater relay to interchange so I'm about as far as I can go. The mechanic at the dealer is uncertain if this could cause the problem. Said he'd order a new one though. Thoughts?
You can read Honda info about that at JustWings.com > printed material > technical information.
1 - 2 of 2 Posts
