1 - 4 of 4 Posts
my 03 will lose the headlight only for a while and then it's working again. when it is not working the bright light indicator does not work either. where would you start looking first. I appreciate any suggestions.
thanks
starter switch
Sounds like your starter switch needs cleaning. Next time you notice the headlights out, pull out on your starter switch and see if they come back on. If so, clean the starter switch. If not, swap your headlight relay with another one and see if that clears the problem.
:agree:
I had the same problem. Starter switch was replaced under warranty. If not under warranty, you'll probably be able to clean it out.
Clean your start button. That is the only thing that will cause all four headlights to malfunction.
>CLICK<
1 - 4 of 4 Posts
