1 - 1 of 1 Posts
GL1800Riders.com Vendor
Imagine the situation: you turn the key and hit the switch, but nothing happens. This is unfortunate and can happen to anyone. There are a few things more frustrating than that. If you don’t have a jump starter, chances are you’re not going anywhere anytime soon. Push-starting may do the trick in some situations, but regardless of whether you have this useful skill and whether it helped, you’ll need to have your starting & charging system checked.
If your bike doesn’t start, there is a good chance you have a bad battery. You see it clearly if the headlight is dim and you don’t hear the starter turn the engine over. A bad battery can no longer hold a sufficient charge to start the engine. Sure, in some cases the battery can be revived by a good recharge, or you simply need to clean its terminals. If not, you’d better get a new one. Take a look at the popular AGM factory-activated battery and a 12V battery jump starter by Torxe.
Torxe™ - 12V Battery Jump Starter
Specifications:
D/C Voltage: 12V
Battery Type: Lithium-ion
Features:
Powerful, lightweight lithium-ion battery technology
Spark-proof and reverse polarity protected jumper cables
Includes 12V car charging adapter and AC charging adapter
Jump starting/recharging cycle life: 1000 cycles
Two 5V 2A USB ports for charging cell phones/smartphones and other mobile devices
Cell phone/smartphone charging cable with adapters for all common mobile device charging ports
12V, 16V & 19V charging port for laptops, monitors, cameras, etc.
Includes charging cable & 8 charging port adapters to cover all brands and types of electronic equipment
Built-in LED flashlight with flashing mode on power bank
LCD display shows percentage of power and output voltage
Portable air compressor with integral pressure gauge
Compressor includes 20” power cord and 4.25” air hose for easy tire access
Compressor includes built-in LED flashlight
Includes inflation hose adapters for airing up sports equipment, camping gear, etc.
Compact, hard plastic carrying case with handle has separate compartments for power pack, compressor, and all accessories
Operating temperature range: -13ºF - 176ºF (-25ºC - 80ºC)
Warranty: 1 year
Torxe™ - AGM Factory Activated Battery
Features:
Advanced AGM (Absorbed Glass Mat) technology
Maintenance free, never needs water or terminal cleaning
Low resistance for high current delivery on-demand and fast starting
Pure lead plates and large plate area provide high cold cranking amps and reserve capacity
Can be repeatedly charge/discharge cycled at up to 80% depth of discharge
Vibration resistant
Spill proof
Strong, durable plastic case
Click on the image to enter the product page at MOTORCYCLEiD.com.
To browse the full catalog of Torxe products, click the "Shop Now" button below:
Or use this link
Give our sales team a call at 888.903.4344 (Toll-Free) or 1.732.867.9995 (International) and we'll answer all your questions.​
1 - 1 of 1 Posts
