The terms “Isolator”, “Power Distribution Module” and “Fuse Block” are often used interchangeably. And while these devices do share many common traits, they are in fact very different.
Similarities:
Isolators are used to keep aftermarket run, brake, and turn lights from overloading the bike’s light circuits or computers. This is especially important for 2018+ Gold Wings. Isolators have the following features:
Note: No isolator interfaces with the 2018+ CANBUS system. They interface with the light system. The CANBUS is used only by the bike’s computers to talk each other.
Power Distribution Modules (PDM)s are used to keep aftermarket accessories from overloading the bike’s electrical system. Accessories include heated gear, navigation systems (Garmin, ect), radios, cameras, radar detectors, phone chargers, etc. PDMs have the following features:
Note: PDMs do not interface with the bike’s light control system.
Fuse Blocks are used to connect multiple aftermarket lights and/or accessories to the needed circuit and provide fused protection for each circuit. They often are used in tandem with isolators. Fuse Blocks have the following features:
Note: Most but not all isolators and all PDMs have the core fuse block function of connecting multiple aftermarket lights and/or accessories to the applicable circuit as well as having more features than Fuse Blocks.
www.gl1800riders.com
Similarities:
- Set up an electrical system that is separate from the bike’s electrical system.
- Have manual fuses or electronic circuit breakers to provide circuit protection.
- Receive power and ground from the battery.
- interface with the bike’s light control circuits.
- have physical or electronic relays
- switches circuits on and off
- may also have an Accessory (ACC)/Switch Power and/or Always Hot circuit too
- may have a single electronic circuit breaker for the entire device or individual manual fuses for each output circuit (Electrical Connection and Rivco do not have any circuit protection)
- provides constant power
- may have physical or electronic relays for ACC/Switched power
- may have a single circuit breaker for the entire device or individual manual fuses for each output circuit
- do not provide isolation for the bike’s lighting system
- do not switch lighting or ACC circuits on and off
- have individual manual fuses or electronic circuit breakers for each output circuit
Importance of Isolators on 2018+ Gold Wings (Updated)
Sometimes, a picture is worth a 1000 words The Graphs are the Most Important Item to develop understanding Of note: Honda changed 2021+ bikes, either reducing the capacity, or the new rear lights use more power, or both. The result is that the amount of power available between the...
