Had a J&M Blue Hub installed at time of trike conversion. Works great, only issue is alternator (or engine) whine
through the corded headsets. Doesn't happen with these helmets on the 2012 Wing, just the 2019 with the J&M
setup. Anyone else have this and if so, is there a fix or setting for it? TIA
I suspect the whine you are hearing is from ignition radiation rather than noise on the 12V power line. I would try moving or shielding the JM device and associated cables just to see if it makes a difference.
Ron
Ron
Thank you. I e-mailed J&M some time ago, still waiting for a response from them. Love the product otherwise.
Did you ever get this issue resolved?
