1 - 20 of 23 Posts
I installed my J&M Digital Music player with bluetooth today. Music plays as advertised but I am having major issues with the blue tooth when paired to my blackberry. The receiving caller has a high pitch squeal on their phone. Has anyone else seen this and what did you do to fix the problem. I have a 2008 Nav.
I have already removed my Mice mutes and J&M passenger volume control.
trax55 ,,,,,
very sorry, we have had virtually NO problems with these new units ,,,,
what brand/model of helmet headset are you using ? ,,,,,,
any problem with your headset when using the intercom or CB ? ,,,
any type of mike-mutes or simlular systems installed on your Wing ? ,,,,,
do you have another phone around to try instead of your BlackBerry ? ,,,,,
I will help you figure this out ,,,,
Discussion Starter #4
Using J&M headset with Nolan helmet.
No problems with intercom or CB and have the buzz with and without the intercom turned on.
I have disconnected the Mike- mutes and still have the buzz
The blackberry worked great with ed sets jumper and the garmin 665.
__________________
Hmmm I didn't have that problem...a couple of things come to mind...as you accelerate does it go higher? Have you played with the volume on your BB?
replacement on the way
Did not have a chance to see if the pitch changes with speed because it is making the noise without the engine even running. I will be installing a replacement unit this weekend.
Just a comment. I have used J&M headsets, helmets and other products and have been 100% satisfied.
I have installed this this unit and no real problems...One thing though is John makes things right!! Let us know how it goes.
trax55 ,,,,,
John,
Mic-Mutes can not cause any kind of noises. It is a passive device with no amplifier, and also does not extend the audio wiring throughout the blke to pick up any induced noises.
Just say'n !
Discussion Starter #10
Replacement unit going in
Received the replacement unit and will install it this weekend. Hope it does the trick.
Discussion Starter #11
Noise still there
Installed the unit today and still have the buzz. Sent John an e-mail and am waiting for assistance. Has anyone else experienced this? Hope I didn't spend $300.00 for a system that works worse than the $80.00 Ed Sets splitter.
trax55 ,,,,
I read your email today, and to be honest I am stumped,,,,
we have over 1,000 of those units out there already and no one has brought a problem like yours to my attention ,,,,
are any of the wires or parts from your old Kennedy system still plugged into the wiring harness on your Wing ?
Discussion Starter #13
And the answer is
The J&M MMDM_IPBT_GL18 is not compatible with a blackberry 9630. I have tried two Blackberry 9630's and both have the squeal. When I used a friends phone it worked well. John has had no known issues besides my phone. Please respond to this post if anyone has had similar issues with this phone or any others. I am waiting to see if J&M will take the unit back. If not I will have a slightly used unit for sale.
Hows it working now? I'm interested in that kit but will pair it with a HTC EVO
I, too, am having issues with the unit I just installed yesterday.
Here are my symptoms, copied from another post I made before I found this thread:
1. Engine hum through the headset, whether the unit is being used or not.
2. White noise through headset, whether the unit is being used or not.
3. A small "pop" sound when I apply the brakes, whether the unit is being used or not.
These all point to a ground problem, in my mind. But the unit doesn't ground to anything. I'm at a loss.
By chance do you know anyone else with a BB 9630 to try and see if there may be a defect in your phone alone?
Blackberry phones have always had a touchy Bluetooth stack try another make of phone to qualify the source of the problem.
Also if your having noise issues with one of these type units try moving the cables that link tot he headset cables this can be a source of noise on all MIC splitters, make sure that you are not tied to other cable on the left of the bike as this is the power side.
If this is a response to my post.....I wondered about that. I did, in fact run the wires up the left side of the bike, right past the alternator. It was hard to do it otherwise, as everything runs to the left fairing pocket. But I did think of it. I might unplug everything and see if the hum is still there. That would tell me a little, at least, I think.
Come to think of it, I zip tied the wires to another group of wires running up the left side. So that could be the culprit. I'll mess with it when I get off work.
Its very common for MIC splitters to pickup noise on the bike and as you have two of them with this setup that is amplified, separation has always been the best remedy, try unplugging the headset junctions one at a time and remove the splitters see if that is the issue
So I unhooked everything. I uncoupled every single connector the system has and reconnected the headset leads back to how they were originally. Lo and behold, the noise is still there.
I'm madder than ever now. I now have noise where there wasn't any before whether the unit is connected or not. And the worst part is, I can't prove a thing. I essentially just paid over $250 to screw my brand new bike up, and have absolutely no recourse.
Wonderful.
1 - 20 of 23 Posts
