1 - 11 of 11 Posts
I have the opportunity to have a FREE (good price) J&M passenger controller with the volume control and the PTT. We do have a lot of wind noise from her because she only wears a 1/2 helmet. I was going to get the Mic-Mutes because I've heard good things about them; but if I can save $120 or so I'd really like to. Does anyone have experience with this and is it functional? I don't mind trying the J&M and then going to the mic-mutes if it doesn't work; but I'm trying to save the work of installing if others can tell me it just doesn't work. Thanks for your help.
For what it's designed to do, the J&M Controller works great. Easy to install and the ergonomics of the controller are well designed.
If you're looking for the J&M controller to reduce wind noise on the intercom and during her CB transmission, then you should get the Mic-Mutes instead. The J&M does just what is says it does, nothing else. Now the J&M controller in combination with Mic-Mutes is fantastic! If you decide to just go with Mic-Mutes and their PTT switch for the CB, they only thing you give up is the rear volume control.
My suggestion would be to get the J&M Controller (since it's free) and then order your Mic-Mutes without their PPT switch since the J&M already has a CB PTT! Then you have the best of both worlds!
I have the JM installed, and it works fine for us. You may want to add Mic Mutes at some point, but I haven't seen the need yet.
I installed both the J&M unit and the Mic-Mutes............the J&M can only turn off the passenger mic so that's only half the solution. I mounted the J&M on the right side as it was in the way for passenger mounting on the left side.
The combination of both is perfect as already mentioned...........
Great, thanks everyone. Sounds like both is the answer. Now--I'm pretty much useless when it comes to mechanical stuff, espcially wiring. Can someone describe how to install both? I've seen the directions for the Mic-Mutes somewhere on here; but what is the difficulty in installing both?
To install the J&M, you remove the seat, plug the J&M unit into the already existing plugs on the bike and connect the electrical wires to the accessory terminal on the fuse box. VERY easy!
We just added the HUGE rubber covered foam windsocks to the microphones and it made a big difference in wind noise. At this point i am going to hold off on the mic mutes and just use the big ugly foam covers. These were from wingstuff @7.99 ea.
Discussion Starter · #9 ·
I thought I might be able to figure out the J&M OR the Mic-Mutes but was concerned about how they BOTH work together.
Anyone have any diagrams or instructions as to how they wire in together?
Copilot,
It's really simple. The J&M controller plugs in under the seat, in 2 places;
1- 5 pin headset lead connector
2- 2 pin CB PTT connector
You simply place the 2 Mic-Mutes adapters in line with those 2 connectors.
Headset; unlpug the existing connector for the cable that goes to the passenger helmet 5 pin DIN plug - insert both the J&M 5 pin and the Mic-Mutes headset adapter in the string with the headset cable on one end and the bike wiring on the other end of the string. (Just plug the 2 together.)
PTT; plug the Mic-Mutes PTT adapter and J&M 2 together and into the unused 2 pin PTT connector.
Discussion Starter · #11 ·
Thanks Morph. It really does sound easy. I wasn't sure if all of the plugs were compatable, used the same Gl1800 plugs or required some splicing. I might even be able to get this done. I LOVE THIS BOARD. OK, now when is Hal having a spring sale?
1 - 11 of 11 Posts
