  • Hey everyone! Enter your ride HERE to be a part of this month's Ride of the Month Challenge!
1 - 20 of 20 Posts
Do the inserts covering the fog light space in the front lower cowl knock out easy or do they need to be cut out? Tips are welcome.
Cut mine with a dremel tool, a hot knife will work.
Use a hacksaw blade. Just the blade. I made my cut along the inside of the cover and then cleaned it up with a razor knife. If you try to knock the cover out, you will end up with a mess.
I cut mine with a dremel and couldn't clean up to look oem so I made my own gromet out of small rubber vac hose, just sliced with razor and fit it around cut area. looks factory after that. I believe I saw somewhere a Honda instruction manual for fog light install and it listed the gromets in parts list but mine didn't say or have them so I Macgivered them!:thumbup:
+1 for Dremel.
Used a sharp knife when I put em on the stock cowl and used the dremel when I bought the Show Chrome cowl. Cut em out with it then used it to smooth down the tabs. Couldn't tell there were ever caps over the holes.
Thanks all. Yeah, I didn't think they would knock out easily. I'm going to have the OEM one color matched.
I used a Dremel with a cutting wheel on it. I stayed well away from the circular inside of the finished edge and then came back with a sanding drum bit on the Dremel to clean it all up. Keep the speed down so if it kicks on you then you won't have the bit take off like a runaway train. It works just dandy.
I used my smallest pair of end cutting pliers.
Ditto, hacksaw and cleaned it up with a razor knife. :thumbup:
32T hacksaw blade
26 second job
I used a pair of Dikes. Diagonal cutters for those of you that have a dirty mind
hacksaw blade, then a 1/2 round file on the high spots - only stroking with file from the front side toward the back side. Cleaned remaining burrs with a utility knife.
I agree. Snip through all the tabs with a pair of side-cutters just to get the "knock-out" out of the way, trim remaining stubs using a utility knife with a sharp blade. Start on the top tabs so that you'll have your procedure perfected before moving on to the more visable tabs. Dress the back of the "lip" with a fine file and some sandpaper afterwards (to where when you look through the holes from an angle, you don't see any remnants where the tabs were on the back-side of the cowling). Just makes things look half-fast if you don't clean it up and after you get it back together, you'll wish you did. Takes less than 5 minutes to do both sides but time is on your side. You're in this deep, may as well do it right. It's like most Goldwing projects...simple to do, just a pain to get to.
You can easily do a better job than most dealerships would do as its your bike and just a job to them.
Z
I did several using Lewis's (EC) instructions and they all turned out great, good luck, as always thanks Lewis.
Discussion Starter #18
Thanks all for the excellent suggestions. This board is awesome. I used the hack saw blade and smoothed out with the dremel tool and fine grade sand paper. Worked great. Now it's off to the painter.
:agree:Thats how I did mine.
Kurt :thumbup:
The proper tool is a side cutter.
[ame="http://www.amazon.com/Xuron-170-II-Micro-Shear-Flush-Cutter/dp/B000IBSFAI/ref=sr_1_1?s=hi&ie=UTF8&qid=1308142562&sr=1-1"]
[/ame]
1 - 20 of 20 Posts
