I'm buying an 04 with Kuryakyn stuff that has burned out LEDs. Has anyone tried replacing the LEDs? What type of LEDs are used by Kuryakyn?
Ring of Fire: http://www.hondadirectlineusa.com/store ... =956778207
Trunk Bar: http://www.hondadirectlineusa.com/store ... =956778207
and Stealth Lightbar: http://www.hondadirectlineusa.com/store ... =956778207
I haven't tried removing the parts yet. I expect that the Trunk Bar and Stealth Lightbar will be glued in place ? Are the LEDs individual or are they some sort of array that can't be opened and repaired?
replacing leds
The LED's are on a circuit board and has minuture LED's and resisters I won't say you couldn't repair them but you would have to identify the resisters and find a supplier for the tiny leds.I found it was easier to just replace the unit...Jim
Jim,
How are the trunk pieces attached ? Can they be easily removed ?
LED Lights
Morph, just replaced mine as I did not know how to repair. They are in strips and attached by double face tape. Very easy to remove and replace. I called Venco Wings and they sent me replacements.
Is there anyone willing to give up their replaced part so that I may attempt to hack it ?
If successful, I’ll find the replacement parts and share it along with the repair procedure.
I also need info for replacement / repair of the Stealth Lights and Ring of Fire.
Morph,
A year ago I posted the following on this forum to help me try and fix my Ring-of-Fire boards.
http://www.gl1800riders.com/forums/view ... highlight=
If you look at the thread, I did post the circuit diagram including resistor values.
I subsequently hacked on one of my boards and had some success in repairing it, but not enough to make it usable. There is quite a bit of corrosion that attacked the points where the pelletized resistors and LEDs connect.
I bought some silver bearing epoxy to connect some new resistors that I purchased, to the LED devices. I also used the epoxy to add jumpers to bypass bad connection points.
If you want my old boards, I will be glad to donate them to your research activity. One has been hacked on a bit, the other I have left alone. Both have some LEDs that won't light.
If you want to try the silver bearing epoxy to fix your boards or to experiment with, I could be persuaded to donate that to you as well. It was a bit pricey, but I can't think I'll have any use for it in the near future.
I bought new Ring-of-Fire setups, and note that Kury has totally encapsulated the new style boards in a clear plastic sleeve to keep the corrosive stuff off of them.
Kirk
