1 - 4 of 4 Posts
Electrical Connection LED Headlight Bulb Kit - $75 + shipping
This is an LED headlight bulb kit that has never been installed. Bought it & changed my mind. This kit is made by Electrical Connection (EC01052) and is designed to replace two of the four stock H7 headlight bulbs. You can replace either both low beam bulbs or both high beam bulbs. If you want to replace both low and high beam bulbs, you will need to order two of these kits. This will fit all Goldwing GL1800's and F6B's from 2001-2017.
Low Beam Cutout Harness $10 + shipping
This is a low beam cutout harness and was never installed on the bike. It is made by Electrical Connection and is designed to turn the low beam headlights on after the bike is running. Your Goldwing shuts the headlight off when you press the starter button. This process of cycling power (on with the key--off with the starter--on once running) is hard on both the bulb and especially on an HID ballast. This harness changes the trigger to your low beam relay so that the low beams only get power after the bikes engine is started. This installs easily under the seat and will fit all Goldwing GL1800's and F6B's from 2001-2017.
Rear Accessory Light Plug & Play harness - $20 + shipping
This is a new style rear accessory harness and was never installed on the bike. It is made by Kuryakyn and is designed to allow the new lighted rear accessories from Kuryakyn to be a plug and play installation on the new 2012-2017 Goldwing. One of these is required for any Kuryakyn rear lighted accessory to be installed on the 2012-2017 GL1800. Once you have this harness installed, all future accessories are a simple plug and play addition. Only one harness per bike is required. This will NOT fit Goldwing models 2001-2010 or the F6B.
366524
366526
366522
366523
Have confidence in this seller. He just sold and shipped me his aftermarket seat and it is like new condition. Packing was excellent. Peace. D
1 - 4 of 4 Posts
