1 - 4 of 4 Posts
if you're there lewis.
i got an EC run/brake adapter for my UK 1800 spoiler.
the wiring is slightly different on the uk bike as there are no stop tail lights in the saddlebags only the trunk.
for this reason there are not the plugs behind the licence plate that are on the US bike.
nowhere to plug the 2 pin connectors other than the brown connector that feeds the licence plate light.
is there a work around?
peter
Peter.....you can use the brown with white stripe for the running light function. Green with red stripe would be the brake wire. I am fairly certian that the wire coming from the 3 pin connector is the running light wire. I will be back in the office Monday and get you more direct info.
1 - 4 of 4 Posts
