1 - 3 of 3 Posts
I am in the process of replacing the rear shock on my '04 GL1800 with a Wilbers shock and replacing the fork springs with Wilbers springs. I intend to raise the ride height for more cornering clearance. Most likely the side stand and center stands will be a bit short. Are longer stands available? Weld a piece onto the feet? I would appreciate suggestions. Carl
Look at the Kury side stand. From the complaints from some on the gl1800.org board they are having trouble with it being too long. So for your use it might be the thing to replace the shorter stock sidestand.
The Kury side stand is longer but they give you instructions on modifications that will change the lean angle.
1 - 3 of 3 Posts
