1 - 8 of 8 Posts
anyone had a noise in final drive on aGL1800. the noise sounds like abearing or gear howl mostly on coast. loudest at about 40 mph. gets louder as the bike gets warmed up. it is related to road speed not gear selection. it started almost as soon as i got bike. has about 2000 mi. now and has gotten lowder. can even hear it at highway speeds,75 mph.
Have you checked the fluid level?
Mike, don't mess around with it. Take it to the dealer. Several possibilities, some could be dangerous to your safety!
to all thanks.
i have checked the gear oil ,the boot, the tires are new. it's going in anyway for the frame fix anyway soon. had a couple dealers ride it they said it was normal. i don't think so. will put more pressure on them. thanks.
Mike,
I have heard some noise from my drive. I think some noise is normal due the lash. I notice some play when riding with no load on the drive. Ride slowly with minimum throttle. If you hear the noise at this time I think it may be lash noise. Compare yours to a friends and press the dealer if necessary.
If several dealers have said all is OK it likely is. All of us experienced strange noises when our Wings were new. The root cause comes from sitting atop a 1800cc engine and you and it riding behind a wind screen. You will adjust to the noises. We all have.
1 - 8 of 8 Posts
