When I hit a bump with the CB on there is a loud noise in the headset. It never happens with the CB turned off. The CB works just fine otherwise. I suspect that something is loose. But what? I'v check everything I know to check.
Any ideas?
Do you have anti-lock brakes?
If so that's the noise.
I get it all the time.
The brake system is self checking or something like that.
The guru's on this site can explain why it does that.
Yes the bike is an 04 with ABS. What would the ABS have to do with the CB?
27Mhz is probably the perfect frequency to use if you wanted to pick up interference, The abs on my BMW did this too.
Jas
I found that if I go over a bump w the CB on That if I put my finger holding the push to talk button (preventing it from keying) that the noise stops!
FF
