Have a 2005 GW with Champion trike kit, solid axle. A maintenance sheet from Champion supplied by the previous owner states that the shaft spline and universal joint should be lubed every 3-5k miles if equipped with lube nipples. I can clearly see the universal joint has no such nipples but am not sure where to look on the shaft. Has anyone seen one, found one?
