Same here. I have a magnetic drain plug, and at 61k on the bike, I have yet to find anything on the plug, with oil changes every 5-6k. Motors are made better with todays machinery, than in the past.Well that sucks !!!
For wherever reason, many with transmission problems will think that a magnetic drain plug is a good idea. However, when I pull those magnetic drain plugs there is never anything attached to them.
Not sure ... but at least he knows there is something going on.I wonder why Wi Wingers magnetic plug catches so much sediment ?
Well that sucks !!!
What is "Honda's dino oil 4NP 10w40" ??? I've never heard of it.It's not a lot of crud, just some black oily film covering the center tip.
There's some every time I drain my oil using Honda's dino oil 4NP 10w40.
You think it's something to be concerned about?
Guessing he means oil recycled from dinosaurs....i.e. real petroleum product, not a synthetic...What is "Honda's dino oil 4NP 10w40" ??? I've never heard of it.
The best and most popular oil for 5th gens GoldWings is Honda GN4 conventional.
Not using the synthetic oil? (Flame suit on, flame away >I wonder why Wi Wingers magnetic plug catches so much sediment ?
That is normal. Wipe it off on a rag and you'll see it has tiny metal flake "dust" on it. Most likely they are pieces of the semi-metallic clutch plates.It's not a lot of crud, just some black oily film covering the center tip.
FINALLY....Someone who under standsThat is normal. Wipe it off on a rag and you'll see it has tiny metal flake "dust" on it. Most likely they are pieces of the semi-metallic clutch plates.
If you have "chunks" of metal on the magnet, there is cause for alarm but if it's just clutch "dust"...it is normal.
I've had it on every oil change since new. Mine has 72K on it and I change about every 5K.
