I know that it has been posted before, but I can not find it. What kind, size etc. are the ones used on the wing, front and rear?
Joe in Redding
.463 hole diameter. Right angle is much easier to check pressure. Tho if Honda had drilled the hole in a better spot, one could use straight stems.
:agree: On the patchboy from Shinhopples. I just ordered 10 of them. I change out a few tires and keep them on hand. I might ad great deal on Dynabeads.
Actually you can use a short, straight, metal or rubber stem without any problems. My air chuck is a Milton which works on straight and 90 degree stems. I carry a small, Schrader, curved stem adapter to use if I get stuck someplace where the air chuck will not fit a vertical stem. First thing I did when changing to vertical was to be sure I didn't have a problem with ANY air chuck on the road like at 7-11's.
