FYI
I just did a 85 mile road test with these tires on my 2018, the front 888 is the correct size, the rear 888 is the 180/60/16 HL same size on the previous generation. The only difference to me was the handling, it seemed a little easier to flick it around but that may be the new tire "effect". It takes the same effort to put it on the center stand and the side stand isn't affected either, if you use a tire size calculator you will see the only real difference is width (7.87 vs 7.09)
