Thanks Andy. This is helpful. The manufacture of the Tridium said they wont work with other aftermarket kits and I'm hoping someone found that they will work with the Muth's or came up with a workaround.
Glad to help.
It did take some time to chase the turn signal wires down to the lower cowl. I had my windshield cowl and windshield off to change the signal flasher for the SoCal directionals and to run the sync cable across between those new directionals. If you are not changing the primary/OEM to LEDs you won't need to do this.
Just so you know, I added the Muth later than the other two. Everything worked fine before and after. The Muth mirrors came with harness adapters which are needed on your bike (2012-2017).
Of course if you have the latest Muth with the radar lane change assist then you will need to tear into much more - and I want to know how well they work!
Which, by the way, leads to an offer to assist with any of this. Come on North on a sunny day and we can make this happen. Of course it would probably take longer to get here than to actually do the install.
