1 - 3 of 3 Posts
The right side mirror turn signal won't work ?
I thought the bulb needed to be replaced
so I replaced the bulb and it lights up like
its supposed to but when I activate the
turn signal it goes out and the dash indicator
blinks rapidly ? Left one works fine so now
what do I look for ? Thanks for any help
Are you sure you used the correct bulb ? Does it and the rear work on the four ways ? If so sounds like a bad connection, try spreading the wire contacts of the bulb.
7443 bulb I think that's the right one . Four ways ? The flashers work ?
1 - 3 of 3 Posts
