whats your oil look like at each change. does it need changing that often?Why not?
I use Amzoil Severe Gear 75W-90 every second engine oil change.
If you follow the mothership's guidelines, final drive oil changeout is recommended every three years.whats your oil look like at each change. does it need changing that often?
X2I change my GEAR OIL every OIL CHANGE. It cost just pennies so why not have fresh fluids?
I guess if you were riding in water up to the final drive all the time or on extremely dusty roads 100% of the time you probably would want to change it out at more frequent intervals.@murf. i knew that, from readingerr, browsing, err, glancing at the manual, lol. just wondering why hes changing it so often and if his needs more frequent changing. under what circumstances would it need more frequent changes?
Gives me a false sense of Security...at least.whats your oil look like at each change. Clean-as-a-Whistle. does it need changing that often? Nope!
