can these be turned off?a switch maybe?i have BACK OFF modulator. It has to be wired in. i had it done so the box is under the seat. it was the easiest way to do it. Do not ask me how it was installed, i had a cycle shop do it for me. Everyone that has seen it is impressed with it and say you can certainly see it and it grabs your attention.
Put the headlight and taillight modulator on, both work fine.I am planning on installing a modulating brake light on my Wing. Which is the best?? I dislike cutting into wiring, so would prefer a plug in type, Wing compatable.
Where did you pick up the wire for the brakes?You want MODULATORS. YOU REALLY WANT STINKING MODULAORS!!! DO YOU REALLY THINK YOU CAN HANDLE MODULATORS??? Well then CHECK THIS OUT!!!!
http://www.youtube.com/watch?v=K_utfkhh_pg
DOC
I'll second the Comagination products. I've used them before and they are bombproof.
Nice write up, Chief. However, it looks too complicated for my tiny brain!!I use the Signal Dynamics Back-Off Wig-Wag modulator, very visible and fairly easy to install. Here's a link on how to do it on a Wing, and I've had no problems with it.
http://www.floydweb.com/images/goldwing/brakemod/brakemod.html
Initially I set mine to flash and then go steady, later changed it to pulse every few seconds. Made a difference for when your at a light for a bit and traffic is coming up on you.
Am wondering if the LIN 3 can be tied into the backoff modulator?If I may also suggest if you want a brake light that will grab peaples attention go to this website www.swps.com and look for the light that says LIN 3 it cost $60. And it is an exact fit where the reflector is at on the rear fender. This puppy will grab your eyes long before anything else. It's the same model that the cop cars uses or for $90. You can get the Mack daddy of them all. It's an easy install a couple of splices and it's done.
I have one on mine and get alot of compliments and holly cow that thing is bright. Just a thought. Sorry for being off your topic.
