I have a 08 1800 with a 11 motor trike 2+2 spider kit with solid axle. I do not have running boards on it. When it rains the tires carry the water to the front of the fender then the water with all the road grimegoes all over the passenger and the driver so bad you can not see out of the wind shield. It appers when the water is coming of the tire the wind catches it and blowes it all over. It is real bad. I had o5 motortrike kit which was a spider only and never had this problem. Does any body have this problem? If so any suggestions.
This is a serious problem as the road grime gets on the inside of the wind shield and also my glasses.
