Sears Craftsman socket 1-11/16, 12 point. $20.
http://www.sears.com/shc/s/p_10165_26151_00947784000P
A few points. It fits a bit loose. You need to carefully hold it down squarely, tip it a little and it will slip. I've gone only to 30 ft-lbs with it.
The Sears socket is JUST deep enough, others may not be. It does need to be 12 point, so it has points at 90 degree angles. It's 3/4 drive, you may have to also purchase an adapter.
Other alternatives are substantially more expensive or require fabrication.
