i posted afew weeks back that on my 06 wing the alternator shorted out , and burned up the wire harness. it was not even a month old. after three weeks its home. it happened while i was at sturgis. everything seems to be fine, but there is one thing that bothers me, now when i start it the lights are a little dim and then its like the alt kicks in and the lights get brighter. it takes about 30seconds after starting for this to happen. it also does this when the brake lights come on but the lights go back to bright after a couple of seconds. does anyone else have this happen or should i be worried that something else is wrong :?:
Fred or Stu posted information about the charging system. There is a delay after engine start before the alternator begins to charge. I have noticed it in mine by the LED voltage indicator. Sounds normal. Yes, with ABS, there is a large load on the system when brakes are applied.
Bob D.
Hello without ABS you can see the headlights dim a little!!! look at it from the rear when brakes are used.....LOST of light=lots of juice=slightly dim headlight...thats OK with me...chuck
My '06 does the same thing. I can watch my voltmeter and see when the alternator begins charging- usually about 15-30 seconds after starting the bike.
