1 - 11 of 11 Posts
I have just got back from a long trip and wanted to change the oil.
I had only changed the oil once before on this bike.
I put a large allen wrench in the plug that sits (facing down) just behind the oil filter on the left side of the bike. Only 2 Tablespoons of oil drained out.
Then I noticed the real drain plug and proceeded to change the oil.
What is this allen plug for?????
Thanks.
Allen plug
I MNTodd
Can you put a picture would help a lot, I'll go check on my Wing.
FlyBoy2121:thumbup:
Thanks.
It's a plug covering a hole that's used somehow in assembly, and never intended to be removed.
Try not to lose it, or you'll have a lot of trouble finding the proper part number, it's a very standard Honda part, but not on the GL1800 fiche.
DAMHIK.
Just like stated above, when machining the case, oil passages are drilled from the outside then capped. You removed a large oil passage cap. There are a total of 5 on our engs. It is best not to remove them. Also, you will see red lock-tight on the threads. You should clean the threads and lock light it back in. The service manul does not give a torque spec but 30 ft/lbs would work. Don't forget to check for leaks after.
That would explain why it was so difficult to remove. That thing was super tight. Must have been the loctite on the threads making is hard to remove.
I will go get some red loctite and re-install with that.
I love this message board. Lots of good guys
on here able to answer questions.
thanks.
Ummmmm, it might be red, but,,,,,,,,,,,,,,,,,,,,,,,,,,If you have dealt with red Locktight as we know it, you know it wouldn't turn loose without heat and a lot of cussin and pounding, or the very leaste a long cheater.
Lock it back in, but blue stuff and leave it alone will be plenty. What it is, has been answered so no need in that. There could be a need to remove it in the future, don't know why, but as soon as it is sealed really good it could happen, so don't make it impossible.
Best wishes.
Notorious Rocket Scientist
Greetings!
If you look at the inside end of that screw with a magnifying glass, it says "Congratulations! Now put this screw back where you found it and go read the manual."
1 - 11 of 11 Posts
