1 - 8 of 8 Posts
Went for a ride Monday and now the nav shows me off road near a different town than where I am actually sitting.
I've tried turning the bike off and on several times and screen says initializing but I still look like I'm in the middle of the woods. As I drive the map moves under the cursor as it should but the location is bad.
Anyone have any suggestions?
Thanks, Jeff
Have you saved any destinations? Select one of them or create a new destination and it should correct itself.
Bayrec
The problem cropped up when I selected my HOME location and started the route. Started out OK and then went crazy. I'll try setting up a new location tomorrow and see what happens.
I don't think you have to enter one if you have others saved. Another way might be to find a POI and map to it.
I have to agree that I'm not at all a fan of the Honda GPS.... Mine has screwed me up also...............I'm going back to the Garmin GPS, never a problem...
Ronnie
Seems I have read there is a screen recalibrate or something somewhere. Not the same as total reset. I have had to do this on my Garmin a couple times.
As a last resort have you tried a System reset?
Assuming you did all the firmware updates, a system reset should fix your problem.
If not, report the software bug to Honda.
1 - 8 of 8 Posts
