Anyone in N. Utah have a TPMS tool I can borrow? I just went DS, and I'd like to try to get the idiot light to stop blinking at me.
No tool, but here are two good ways to "solve" the TPMS light problem (dead or dying TPMS battery).
If you do the cut & solder fix which is borrowed from a trike conversion instruction sheet, in the rather unlikely event that you'd want to be undo it later, the undo can be a bit more work than the option of adding a SPDT switch to the circuit.
If you add the SPDT switch (shown in the wiring diagram portion of the attached) instead of the cut & solder solution; the "fix" can be easily reversed should you ever decide to do so.
No, mine blinking because I went Dark side (put a car tire on the back). They run at 30psi, so re-registering the TPMS sensors in reverse seems to fool them into working correctly. I actually like the warning, so I don't want to disable it or make it irreversible.
bug, I have one but need to find it, PM me your number.
PM sent.
PM answered.
