Need some advice on rear auxiliary USB port in trunk of my 2012. I plugged in my IPhone a couple of days ago and it failed to charge. Yesterday I did it again and thought I would listen to a podcast. The system recognizes the aux as I see the icon appear, then it disappears. Then I get no recognition or acknowledgement of the 2d aux (Trunk USB) as I rotated the aux button on the info panel. Have an XM mobile mount plugged into the front left aux and had run from rear aux before (as I recollect). Had never had this problem before and guess I am a bit bumfuddled. Am on a long distance ride, and appreciate any ideas anyone might throw out.
Will be on the bike till evening, but will get back to you.
Thanx again
1oldSoldier (Bud)
The USB port does not have charging capability. I have never used mine for anything but a thumb drive. I understand it can be used for and I-Pod or to listen to music stored in an I-phone but it will not stream anything from the I-phone. It is a very simple device, cannot do the tricks of the new stuff.
There may be a difference between years or my memory may not be right (not ridden in five months) but I think mine does charge the phone and I used it to charge the GoPro. iPhone shows on the display as IPOD and all controls work for songs, playlists, skip, etc. Does not work as phone - only IPOD. Have not used for streaming media.
I do wear out cables though. I have changed cables in the car a couple times and I have also had to clean out the jack on the phone as it gathers lint like crazy. Clean that port and try again. Check your cable with either a lighter adapter or AC adapter and see if it charges correctly or just stop by a store and pickup a new cable.
Reactions: Bloodbought1
On my 2013, the USB port in the trunk charges my iPhone and also allows me to listen to streaming music, I listen to Pandora all the time, it will also treat the iPhone as an IPOD if I lose my Pandora station, then I can listen to prerecorded music I have on the iPhone, I am not sure if maybe they made a change between 2012 model and 2013 model for that interface.
First thing to try would be another cable for the phone. Iphones are finicky about the cable being used.
Icon appears and disappears sounds like a bad cable.
Each time the aux button pressed it audio should toggle between the two aux inputs. (usb in trunk and the analog at front LH pocket)
:agree:
I have a 2012... it does the same as your 2013! I listen to Pandora often when I have my IPhone hooked up! I mostly use my old IPod Nano that has multiple play lists! Always charges whatever I hook up!
