1 - 2 of 2 Posts
Guest
Hey all, merry Christmas!
DISREGARD! It was right where Pigeon Roost said it was, hidden inside that rubber boot. Thanks Pigeon Roost
I bought the small square digital volt meter from a link on a post about 5 months ago and finaly have a free day to mess with my wing, including installing it. I have read on posts that there is suposed to be a wire ready to plug into a volt meter or heated grips under the right side faring pocket behind the panel where I am installing the meter. Have looked and looked with a small flashlight but I can't find any such wire laying in there. Any of you know where to find the wires to hook the meter up?
2004 Titanium, and THANKS in advance for any info.
The left and right pockets remove to reveal a boot on each side which contains several connecters. I beleive the one you want is red in color and is a two prong. At the left side it is typically used for the 12 accessory socket and on the right for heated grips. Its down in the rubber/plasic boot so you have to pull the connecters out and then put back the ones you do not need. Been a while and I hope my memory is serving well.
1 - 2 of 2 Posts
