1 - 4 of 4 Posts
Where is the CB plug located? We have the bike torn apart and can't find the bugger.
JLK
CB Connector
It should be under the Top Shelter, to the right and down from the radio connectors you pulled off the bottom of the radio.
It is a white square connector that is probably burried under the wiring...but it is there.
I don't have the ABS or Airbag...but have an '06 with Navi
Cheers
Jan,
I hope that you are asking this, so that you can install the unit. Not the Dealer, pray tell!
Good luck getting her home.
Your last Wing was a looker, so I am sure this one will be as well.
All the Best
Bulldog
You've probably already found it by now....
but if not, keep looking a little bit lower than on previous models.
It's there but buried better than before.
I installed a CB on an airbag model last week. Got lucky when I found it.
1 - 4 of 4 Posts
