1 - 16 of 16 Posts
I had to order new trunk parts, 2 new inner rear pockets, 2 new lower part where the trunk hinges fasten too and new wire harness clips. Also ordered new Polygon exhaust tips to replace the old ones that the Crome is coming off and rusty on the lower side.
Reactions: William Anzik
... and new wire harness clips. .
Can you post a link to the parts fishe and the item number ??? I try to stock all that stuff and cannot picture "harness clips" in the trunk. I can picture them as part of a harness assembly.
Oh those ... last week I had a 2012 in for a CB issue. He was missing one of those on the right side, and embarrassing as it was, I had to tell him I'd never stocked them. I do now.
I’m replacing things that have been wore out or where I have epoxied together in this trunk area. One thing I’m having a hard time finding ate the two black covers on the right and left side of the transmission, all I find is chromed. My black covers on are starting to have this coating peal off
83511-MCA-S40 cover R. Engine
83514-MCA-S40 Mat R. Engine
83561-MCA-S40 cover L. Engine
83564-MCA-640 Mat L. Engine cover
I think this is the part numbers for the black engine covers and the sound dampening material that is inside them. At least these will fit my 2013 Goldwing.
Double check me though!
Found these numbers at Honda Partshouse. I didn’t check if they had them in stock. I did add them to the cart and got a total of $344.00.........Wow they like these don’t they!!!
Discussion Starter #8
wow, I think I’ll hold off, it’s only one small spot on the right cover
Do you know the part # of the trunk harness for a 2014, the one that goes by the hinges.I would like to have a spare just in case?
Not sure if it matters, but what level do you have ???
Are you referring to the engine covers ??? The engine covers are the ones by the rider's ankles and come off to check coolant and oil level.
You might look into the rubberized spray paints that can be peeled off later. I cant recall a brand name at the moment . It's available in colors . I used a can of red to paint valve covers on my 03 . It holds up well. I purchased a used set of the black rear section of the battery/side cover. They had been painted with this type paint .
Discussion Starter #13
Yes those are the ones, but I’m hearing the knocking on the door of 350 bucks. I’ll deal with mine for now.
Reactions: GoldWingrGreg
Check eBay. Often members buy aftermarket ones and put their old ones up for sale.
Discussion Starter #15
My exhaust tip came in yesterday and my trunk parts are out for delivery tomorrow. Yaaaaaa
Dupli-Color is a peelable spray-on coating.
1 - 16 of 16 Posts
