So with respect to rear brake bleed, the common process is listed as follows, but:
ROCKY BRAKEBLEEDING SEQUENCE
1: Front Right Brake Upper Bleeder Valve
2: Front Left Brake Middle/lower Bleeder Valve
Rear Reservoir (under right side chrome engine cover)
1: Front Left Brake Upper Bleeder Valve
2: Front Right Brake Lower Bleeder Valve
3: Rear Brake Lower Bleeder Valve
4: Anti-Dive: bleeder valve on top
5: Rear Brake Upper Bleeder Valve
Do these two additional Steps to be sure you have noresidual air bubble in the rear system!!
6: Pressure bleeding the lower Junction block. (Upperleft side of frame sitting on bike).Follow rubber hose from Secondary mastercyl to the Junction block.
7) Pressure Bleed the top Banjo bolt on the SecondaryMaster Cyl. (To be sure the air bubble is completely out)
Steps 6 and 7 call out the term "PRESSURE BLEEDING". How is this step performed? I have the notorious soft rear brake pedal on my 2003 and the other steps have not helped.
