1 - 4 of 4 Posts
Just installed new brake pedal, honda spoiler with EC turn signals in it, and Kuryakyn reflector conversion for rear fender. Checked all my wiring and it is correct. When I press the foot pedal or the brake lever no change. Not quite sure if they are stuck on, or just not coming on.
Bike is an 09, brand new with 15 miles on it. Any thoughts???
Thanks in advance
thats why i leave it to the experts
Firm Member
Perhaps they are on due to the new pedal. Take it off and see if that changes anything. If you replaced the lever also that is a know cause of problems due to the micro switch not getting engaged or staying engaged.
Start backing our the modifications and see what fixes it.
Good Luck!
Thanks in advance
When you did the wiring.....did you disconnect the battery?....I would check your fuses.
Mark
1 - 4 of 4 Posts
