Hello All,
I messed something up. I was installing or trying to install a flasher unit on my spoiler LED brake light. The unit I got from Amazon required me to cut the brake light positive wire, then wire the flasher in series to the wire. All hooked up and no brake lights. I found the fuse blown, replaced it removed the flasher unit, wired it as it was originally, now no brake lights. Fuse is good. No brake lights with either front or rear handle/pedal. I did install a headlight modulator earlier, so is there anything I could have disrupted in the LH fairing pocket? Pretty tight in there especially with fat hands. 2002 GL1800 base. Thanks in advance, Kim
