1 - 4 of 4 Posts
04 Gold Wing had air filter changed recently , now I have no brake lights or cruise control , I checked the fuses ,they are good. What else can I check ?
Go to the switch on the front brake lever and pull the 2 small connectors off and short them together, the brake lights should come on if the key is on. If they don't, then there could be an issue with the power coming to the switches or an issue with the brake light relay under the seat. If they come on, then the issue is with the switch. Was the gas tank pulled out? Here is the schematic for the brake light circuit:
Might try checking both front brake lever and rear brake pedal maybe one of them works, I recently had to replace the brake pedal switch because brake lights would not shut off and cruise would not work, rear switch was $55 from my local dealer , good luck with yours :thumbup:
1 - 4 of 4 Posts
