1 - 10 of 10 Posts
01, 70,000 Miles
All brake lights work as they should using the foot pedal. When only using the front lever....nothing.
Just a little history....Over the last couple of years while chasing a cruise control issue I've replaced both lever bushings and installed a new right hand switch assembly. I've also had the brake recall done.
Micro switch?
All comments and suggestions appreciated.
Micro switch. Cheapest part to start with and most likely the problem. I wash my bike quite often and ride in the rain. The switches seem to last 2 to 4 years for me.
Switch would be easiest to check and it is good or bad, done. A little CRC contact cleaner may help, but also check that the wires haven't come unplugged from the switches... Left side switch wires were disconnected on my 02 when I bought it.
Sent from my Moto Z (2) using Tapatalk
They get sticky. even just working them for a few minutes, gets them to start working some. That tells you they could use some cleaning spray in there. The switch isn’t too expensive, if you want to replace it.
The micro switch is kinda where I thought I'd check next. Just wanting to see if others has had this exact issue and what they did to resolve it.
Here's the part # I think you might need: 35340-MCA-S41
I can't find this listed on the PARTZILLA diagram anymore, but, if you do a search for this part number, it'll show up as in stock.
IronMan
"listen " to switch should hear 2 clicks one is break and other ( i think) is for cruise set /release thing MINE THE LITE WORKED BUT COULDNT SET CRUISE
Reactions: PastoT
This is the correct number for your 01, but it will probably be subbed to the newer number already mentioned above. #35340-MCA-000
Discussion Starter #10
Thanks techdude.... I was hoping the board expert on all things electrical with the wing would offer an opinion. You helped me with my FI / ECM issue last fall.
1 - 10 of 10 Posts
