1 - 2 of 2 Posts
I purchased a Mustang seat from a good friend that sold his Wing. He had no problem with the heat. The Seat came off a 2012 and I put it on my 2015. On a 45 mile ride in 38 deg temps I got no heat from the seat but the Grips work fine. As the day went on I tried different things and it seems when I turn on the passenger seat heat I felt heat.
Is it possible Honda changed the wiring connector from 2012 to 2015?
Discussion Starter #2
Found the problem....
The Driver and Passenger heated sections are plugged in separately under the seat before going out to the main plug that connects to the Motorcycle Plug.
Those two connectors were switched at some point. It just took removing the seat "again" and following the wires to find the problem.
1 - 2 of 2 Posts
