checked the fuses ,checked the relay ,sprayed contact cleaner in hi/low switch, what next help ?????:bow: oops forgot i also checked the bulbs good to go on that i do have hi beam
Do you have high beams? if no high or lows put your finger nail behind the starter button and pull it out towards you and see if they work then.
Bulbs ... if OEM, the QC is so strick they usually go bad within mins/hours of each others. Wally world has them ... H7 and same brand but since not OEM will go bad within weeks/years of each other. Best to replace non OEMs every 40k as PM.
Did you try reverse? They will come on in reverse no matter what the starter switch is doing. This will eliminate everything but the starter button switch.
