1 - 14 of 14 Posts
I have no power to the fuel pomp relay. Pump is good, I tested it with 12 volts. I get no voltage at the connector, an none to the relay connector. I tested the relay and it tested good. I'm not sure where to look now.
Make sure kill switch is in "on" position and FI light comes on when you first turn key on, then goes off after a couple of seconds. If no FI light, won't get power to fuel pump as kill switch is not making proper contact.
Let us know results. Also, verify fuses good.
Reactions: Bri720a
Ok, so my F1 light doesnot come on, could the switch be bad? Any tricks on how to check that? Also, thank you so much for pointing that out.
Most common reason is the switch is never operated to keep the contact surfaces clean. So you end up with a tiny little connection spot that any little jiggle will move it to an oxidized section and break contact.
Easiest fix to do before disassembly and manual contact cleaner - With key off cycle switch back and forth end to end 50+ times. Then turn key on with switch in run position and see if FI light comes on and fuel pump briefly whirls. If no FI light, repeat step one again and try it. If still no go, time to disassemble.
If you turn on the key and push the starter button with a good neutral light on, does it crank the engine? If so, the kill switch is good and you may have a meltdown of C5 (see thread about C5 and C25 at the top of the Tech board.) Is the front fairing on the bike? If not, the bank angle sensor needs to be connected or it’s harness plug has to be jumpered to provide the ground for the FI/Ignition relay. This relay provides the power for the whole FI system, including the fuel pump relay and the pump on those black/yellow wires.
Good advice from techdude as usual 👌. My recommendation is for the most common, easy to check. His item regarding engine cranking over I forgot about and definitely rules out the kill switch. I just worked on a bike with kill switch issue and had target fixation.
Reactions: techdude2000
Discussion Starter · #9 ·
Hello,
Well I tried cycling the switch and when that didn't do anything I disassembled the control head and tested continuity at the contacts of the switch. The switch works fine, so I closed the circuit physically and still no F1 light or fuel pump action......I'm not sure where to check now. Bike ran fine when I parked it, the next time I went to ride,,,,no start. Any additional advice would be appreciated.
Hello,
Does the starter spin the engine?
Discussion Starter · #12 ·
Yes
Discussion Starter · #13 ·
Yes the engine turns but does not run. I will look for the post on the C5 meltdown. Is this something that can happen between rides?
Not normally. Usually an issue with C5 would cause intermittent symptoms before going completely bad. So, the kill switch is good. First thing to do at this point is check the FI/IGN fuse, then swap the FI/Ignition relay with one like it in the relay bank under the seat if the fuse is good.
1 - 14 of 14 Posts
