1 - 9 of 9 Posts
I was installing a battery charger pigtail on my '07 Wing battery and noticed I was having trouble getting the Positive screw back into the threads. After flashing a light on the situatio, I swear THERE ARE NO THREADS. Has anyone ever experienced this before?
Chris, check and see if a small block fell out of the battery terminal. My battery has a little block behind the hole that has the threads. It will slide around in there. I hope I explained that good enough to figure out.
No threads on the terminal.
A square nut (as opposed to a hex nut) is on the back side.
If you didn't have trouble with the other side, you just got lucky and it didn't fall out. (Of course the negative side doesn't have to be used as long as you complete the circuit by going to any ground.)
You were right. Found it. Interesting design.
Whenever I install any new battery on my bikes, I cut pieces of toothpicks and wedge them behind the threaded square metal block on the terminal. The comoline grease that I use to keep the terminals from oxidation, holds the pieces of toothpick in place. You can substitute vaseline for the comoline grease. Each time, after the initial install, that I remove the battery, the threaded metal block stays always in place for reconnecting the terminals. Yeah, toothpicks. Go figure!
Ride safely.
Mike
1 - 9 of 9 Posts
