1 - 10 of 10 Posts
I have a 08 gl1800 , 9000 miles , noticed noise from start
thought i would wait for major repairs before telling
dealer , possible valves or injectors
2013 Red GW
Whine, whine, whine goes the alternator gears.
Don't wait any longer. You have a warranty use it.
Legend in His Own Mind
OMG you've spun rod bearing!!!:joke:
Kidding, thats just an injector clicking. They all do it occassionally.
on second thought....could the ticking be from a loose Johnson rod?
It's a big job to fix the Johnson rod
I have the same thing, however it starts ticking at 1,400 rpm's and dissipates at approximately 2,200 rpm's regardless of gear. Happens more often when cruising at these rpm's and now I picking up the ticking noise decreasing speed through the rpm range.
Took back to the dealer, tech said he has not heard this noise before and Mother Honda told them to tell me just keep driving it.
It is not, in my case, injector ticking.
If you would be kind enough, let us know what your dealer tells you. Thanks
many years ago
going from 1500 to 1800 had to get used to mulit port fuel injection
the injecters are noisy
also chains instead of belts pretty noisy, for cams
if ya had loud Harley pipes you wouldn't hear a thing
if most Harley guys could hear those pistons slapping they would say what the heck is all that noise
Van, If this is distracting and causing concern;
by all means run the valves, check that the cam
chains are tight. (auto adjusters).
Ask your local GWRRA or others for a good
local wrench or have the Honda dealer do it.
And ask friends to listen and ride.
If it's a distraction fix it.
1 - 10 of 10 Posts
