Coolant change is maybe 45 mins and not bad. Filter call is under the right forward pocket just a couple screws to expose. Drain is very small and easy access front left bottom of the engine. The air filter is more of a PITA. First time is typically a 3-4 hour journey of Discovery, second time it's faster, third and you'll knock it out in 2 hours and be checking things that are only accessible under the shelter. If you search the forum for filter change there are several good ones, or links to complete instructional pictures on what needs to be done. We think the Goldwing was built around it's air filter and high beams! Certainly a lot cheaper to do yourself, maybe $40 and 4.5 hours. I find taping screws close to where they were removed and taking pictures as you proceed helps with the re-assembly of the seat, dash and shelter. Take notes along the way as you dive in. There are several different length shoulder bolts holding the Tupperware in place, they should not be mixed up... Mark them as needed and tape them up close to where you removed them. A the wrong bolt tightened up can crack the plastic, as the shoulders prevent crushing the correct fairing piece or fender.
Sent from my Moto Z (2) using Tapatalk
