Hello all!
I have a couple of questions for some of you out there.
I live in northern Ohio and do not have a heated garage to keep my bike in anymore, it got down to about minus 12° the other day. I have the wing in a non heated shed in the back yard as I do not have a garage where I live. so far I have not had the chance to go out there and investigate because the snow is blocking the door. I am going to get out there and start her up some time this week for sure, I will report back and let everyone know if anything happened.
It was out there last year and everything was fine once the weather got better but it did not get below zero F last year, and prior to 2007 I had a heated garage.
1. what is the coldest your GW has been in not running?
2. What was the coldest temp when you started the engine?
3. Did anything go wrong as a result of the extreme cold?
4. Did you have the factory filled anti-freeze in there?
Thanks everyone in advance for the input.
