Hi guys. Sorry this is sort of long winded. So I picked up a used 2001 GL1800A that has sat untouched since 2009. Only has 19000 miles on it and is essentially in great condition. Here's my issue, kind of stumped at this point, I'm hoping it's something dumb that I'm missing. Have a new battery, cleaned the gas tank added new new gas, replaced the fuel pump motor with a quantum motor rather than replacing the entire fuel pump assembly, new plugs, changed the oil. It started right up no problems. Let it run for about 30 seconds as it was late at night and figured I was good to go. Following weekend figured I would try to take it for a quick ride and it doesn't start. Turns over fine, fuel pump runs when the key is turned on, gets spark seems to not get gas to the injectors. Figured I would check the fuel lines going into the fuel rail, no problem there. Now that everything is back together again the FI light never comes on and the fuel pump does not run. I downloaded the service manual and started making the voltage checks, bank angle, fuel pump relays, fuel pump and the ECM voltages all check okay. Anyone have similar issues or anything else I can check at this point? Thanks.
