Im putting in the oem fog lights on my 2012. . . I didn't like the square holes, so I purchased a lower cowl from an 2008 and lights for 01-10. Put the lights on, got ready to put in the fog light switch in the radio housing panel and its a no go :shrug:. My question is, did they change the fog light switch when they went from the 2001-10 to 2012 models? Or I missing something ?
Chard Member
Yep. You need a switch for a airbagger or 2012 up. Should have purchased light kit for later model or air bagger. Only thing different is the switch.
Sent from iPhone
Yes has to be the Hondaline Foglight AirBag switch Part # 08V31-MCA-10009, I did same as you using this switch. Took lights off my 08 .
Discussion Starter #4
Thanks guys. Mack I appreciate the part number. Tomorrow Im going to the dealer to order the right switch.
One more thing please. Did they change the relay harness that plugs into the fog light switch, or will the 01-10 harness still work on 2012+ models?
